Same problem here, few days ago worked fine.
Looks like that LOG4OM hangs when JT-alert writes to the log file.
LOg4om and JT-alert
Re: LOg4om and JT-alert
I noticed the same issue this weekend. Turns out that I had QRZ lookup enabled, and the site is very slow, perhaps due to CQ CW contest? Disabled lookup and all is well.
Bill WT0DX
Bill WT0DX
JTAlert doesn't write to the Log4OM log file. JTAlert sends an appropriate logging command via the Log4OM logging interface and Log4OM itself does the actual writing to the log file. If the logging is slow or broken, the fault lies with Lo4OM, not JTAlert, which is simply sending a correctly constructed logging command. Log4OM is the program writing to the log file, NOT JTAlert.
de Laurie, VK3AMA
