GridTracker V1.18.0530
HB9BRJ
Post by HB9BRJ »
Since upgrading GridTracker to version 1.18.0530, no more log entries are received by Log4OM. I did not change any settings. Log4OM Communicator as well as GridTracker ports are 2236 as they were before. The communicator's activity log is attached. Anybody else having this problem?
73, Markus HB9BRJ
Re: GridTracker V1.18.0530
Assuming that you have not changed anything in Log4OM and as you say …..
I would think that you either had a bad download and/or install of Gridtracker or a setting has changed in GridTracker.
Did you check the GridTracker settings to ensure that not only is the port number correct but also the IP address and that the 'Enable' button is checked?
HB9BRJ
Post by HB9BRJ »
Yes I did:
Have you had a windows update that might affect the defender software and cause it to block the port?
vk6gom
Post by vk6gom »
I've got the same problem. I uninstalled 1.18.0530 and reinstalled V 1.18.0513 and it works fine. I'm running Win 10 pro 32 bit.
cheers, Norman, VK6GOM
This is a problem with GridTracker, Stephen N0TTL has promised to fix it today
Download the update https://tagloomis.com/downloads/ and it should be fixed
Please report results here
HB9BRJ
Re: GridTracker V1.18.0604
Post by HB9BRJ »
Yes, logging is working again!
73, Markus HB9BRJ
