TQSL is located in C:\Program Files (x86)\TrustedQSL\tqsl.exe
Temporary path is set as C:\Users\Steve\AppData\Roaming\LogOM\LOTW
I think the issue might be my TQSL private password assuming its not the same as my lotw login password
User Profile Problem
Re: User Profile Problem
Are you certain that you installed log4om to "run as anadministrator" as on page 9 of the user guide?
Contact me via Skype at genes1
Email is on QRZ.COM
Email is on QRZ.COM
it looks like I jumped the gun thinking my upload was sorted.
When uploading a new qso to LOTW I am getting an error message saying " The selected station location could not be found" along with "command syntax error"
Steve
Steve
I am out at a bbq just now so please email me a support request as detailed here http://www.log4om.com/log4om-support/ and I will have a look at it in the morning.
Nothing received from you Steve, do I assume that you fixed it?G4POP wrote: ↑28 Jul 2018, 15:59 I am out at a bbq just now so please email me a support request as detailed here http://www.log4om.com/log4om-support/ and I will have a look at it in the morning.
Good morning Terry,
I haven't fixed it at this point but,
I'm wondering if as I had to start from the beginning again with a new config, should I have imported the original SQLite adi database file into this new config rather than just open the database and populate the screen?
Steve
Steve
No just open the existing sqlite database
Your post seems to indicate an issue with the LOTW Station location, check you have exactly the same in Log4om at that shown in the TSQL program as demonstrated yesterday on Skype...
Will be out all day today but will monitor this forum
Many thanks Terry,
LOTW uploads ok now, there was an error in my station location address.
Kindest regards
Steve
Kindest regards
Steve
Read thru the topic but didn't find any good hint how to prevent my issue.
It happens quite frequently that setup/profile is lost at launch. Well, have several backups so restoring config.xml is not problem and so it starts all right but after a few launch I have to do it again.
I'm about to blame my laptop but don't know what to do and it is getting annoying.
Runs under Win10, no virus or spy found, hdd tests end up flawless (1 year old SSD). Using this pc only for hamming - thus not much due lack of time.
Any help is appreciated.
George/ha5uk
George/ha5uk
73, George / ha5uk
