IC7300
G3UGK
IC7300
Post by G3UGK » 17 Sep 2018, 09:54
Log4OM is working well with my IC7300 (Omnirig is set up correctly), with one exception. The drop down menu does not list the 7300 so the radio/log comms protocol is not quite correct. Which rig should I select from the list?
Phil
Re: IC7300
Post by G4POP » 17 Sep 2018, 10:04
Go to the Omnirig site and download the latest rig.ini file then copy it to the C:\Program files (X86)\Afreet\Omnirig\rigs folder
Then restart Log4OM and select the IC7300 file
G3UGK
Re: IC7300
Post by G3UGK » 17 Sep 2018, 10:52
Sorry Terry. I guess I didn't explain properly: Omnirig is working fine using the 7300.ini file. My issue is with the drop down list within Log4OM. Lots of Icoms listed there but no 7300. I'm sure I can select an alternative, but which one?
Phil
Re: IC7300
Post by G4POP » 17 Sep 2018, 11:07
You should see it in the Log4OM Omnirig window as below, perhaps its not in the correct folder?
G3UGK
Re: IC7300
Post by G3UGK » 17 Sep 2018, 11:23
Yes, it is there and I'm using it. My problem is not with Omnirig but with Log40om There's a list of rigs within Log40om one of which has to be selected and there's no 7300 included in THAT list.
Phil
Re: IC7300
Post by G4POP » 17 Sep 2018, 12:31
Phil,
The screenshot I just posted is the Omnirig list from within Log4om
Are you sure that your not confused with the log4om Hamlib facility?
Post a screenshot please
G3UGK
Re: IC7300
Post by G3UGK » 17 Sep 2018, 12:43
Si it is. Can't imagine how I managed to get that up - must have been too quick on the mouse button. Thanks..
Part 2 then: When I select a station from the cluster the rig frequency changes OK, but not the mode. Is this correct?
Phil
Re: IC7300
Post by G4POP » 17 Sep 2018, 12:46
No it is not, both should change providing you have it set so to do in the options
G3UGK
Re: IC7300
Post by G3UGK » 17 Sep 2018, 14:22
I think I'll go away and cry now... closely followed by a strong G&T
Thanks.
Phil
I might even download the instruction manual :)
