Hello I'm new with Log4om
I have 4 calls PD0RVL, PE1RFM,PA3HDP, PA7RA
so I have 4 logs
is it possible to merge this into 1 log into Log4OM ??
And is it possible to chooce more than 1 DXCluster so I will my main cluster VE7CC.net and also the GMA Cluster 81.169.179.220 for sota and WWFF and WCA qso's
tnx
Rien, PA7RA
Merge logs
Re: Merge logs
Assuming your logs are in ADIF format they can all be impoorted in to one database (logbook)
Log4om versikn 1.0 will only display the results from one cluster at a time, however when version 2 is relessed it will be possible to aggregate up to 6 clusters into one display
Re: Merge logs
Tnx Terry for info
My log is abt 88000 qso's is this no problem to import it in Log4OM?
I'm ask this because for HRD this was to big let the support me know
and HRD is very very slow when I import the whole log!
Tnx
Rien, PA7RA
Tnx
Rien, PA7RA
Re: Merge logs
When using the normal sqlite database it's fine for up to about 120,000 qso's over that we recommend using a MySql database
Of course a lot depends on the speed and efficiency of your computer
