QRZ or other lookup
ON7CL
QRZ or other lookup
Post by ON7CL » 06 Apr 2019, 11:42
Hello FM,
The lookup function to qrz or other doesn't work anymore. Yesterday evening it was working, not today.
No changes made and the login and poasswords are correct ?
Whats wrong.
73 - Rudi
Re: QRZ or other lookup
Post by G4POP » 06 Apr 2019, 11:57
First question - What version number of Log4OM are you using - see Help/About if you are not sure
ON7CL
Post by ON7CL » 06 Apr 2019, 12:00
Version 1.36
Post by G4POP » 06 Apr 2019, 12:08
Seems QRZ may have changed something - Checking
HamQTH works fine
ON7CL
Post by ON7CL » 06 Apr 2019, 12:12
Yes Hamqth working, also QRZcq not working here.
on7ec
Post by on7ec » 06 Apr 2019, 12:36
By me same problem
ON7CL
Post by ON7CL » 06 Apr 2019, 15:18
Qrz working again, the problem was not with Log4om.
G4NVB
Post by G4NVB » 06 Apr 2019, 15:24
G4POP wrote:
06 Apr 2019, 12:08
HamQTH works fine
QRZ.COM XML Server was down, now up & running.
http://forums.qrz.com/index.php?threads ... st-5022820
73 de David G4NVB
Post by DF5WW » 06 Apr 2019, 17:27
A small step by step for all users of Log4OM having problems like this:
1 -- Try to login manual to the website which contains the lookup service ...
2 -- For qrz.com users .... If you have an XML subscription check out for the enddate or you got only a smaller package of information.
(like no Gridsquare or something else)
3 -- If you can login manually to the other services contact the service owner and tell him the problem with the Log4OM lookup.
Last but not least -- Don´t forget to inform this community when you receive an answere of the service owner and the problem is resolved ...
