LOTW User indication
pa2kw
Post by pa2kw »
In the filtered cluster window, a LOTW user was indicated by making the time red.
This is not the case anymore. (not sure when it happened, but may be after the last update?)
Is this a "local" issue or is a bug introduced?
73's, Evert PA2KW
Re: LOTW User indication
Just checked and it works fine, see image below, have you checked the options/QSL and Labels menu to ensure 'Show LOTW user' is checked
pa2kw
Post by pa2kw »
GM Terry,
Yes, option "Show LOTW user" was/is checked.
I restarted PC and software, but no positive result.
73's, Evert PA2KW
Have you updated the LOTW users database?
pa2kw
Post by pa2kw »
That's it ......
Thanks Terry
73's, Evert PA2KW
Always wise to update all data files after an updated install because on occasion the Master forgets to include them in the download :D
