Using WSJT-X with FT Alert.
Forwarding QSO logs from FT8 to Log40m
QSO entries forward fine.
However, I get (2) entries per QSO with different time stamp.
30 secs time difference.
Any ideas?
rl2017
Log40M 1.38 Log Entry Duplicates
Re: Log40M 1.38 Log Entry Duplicates
Figured it out!
I had JTalert & WSJT-X forwarding QSO to Log40M
Problem solved.
Now to see which one forwards the QSO in less time.
rl2017
Problem solved.
rl2017
Hello rl2017 ( a name would be nice),
better to forward the contacts with JT-Alert. JT-Alert can show you needed DXCC, County, US-State and a lot more
and also the Worked B4 status in realtime. For me JT-Alert ist the one and only for that ....
Yes but does not give me signal strength.
If it is capable, have not figured out how yet.
Also, JTAlert highlite colors show on WSDJT-X
Nice to see being in sync.
Rod
Rod
JTAlertx
Discovered how to show db.
Settings>Manage Settings>Window - Extended Display
Check the Box Show db (DXCC Name)
Save
OK
Nice!
Save
OK
Nice!
