When i want close Log4OM i get this error popu that says " contatc the author"
thanks 73 F1ABL
Error Warning String
- WARNING STRING.jpg (98.83 KiB) Viewed 3640 times
F1ABL Michel JN24of
Re: Error Warning String
Hi Michel,
do us a favour and tell us what version of Log4OM and what OS (W10/W7 e.g.).
Thank you ....
Thank you ....
Hi, it's a pretty strange situation...
Log4Om is trying to find a text string in french, assuming the DLL has a french localization...
In the PROGRAM folder (c:\programs...\ etc \ IW3HMH\Log4OM you should have a file called LogOMUI.exe.config
It's an XML file you can open with a text editor.
Inside you should see a section called "culture" and you should see something like:
Did you see en-US?
Code: Select all
<LogOMUI.Properties.Settings>
<setting name="Culture" serializeAs="String">
<value>en-US</value>
</setting>
</LogOMUI.Properties.Settings>
Hi dear friendssame problems here:
a) I get the same warning "string loading is not available for language en-US please report..."
I searched the above mentioned file and the en-US persists already.
b)When I open or close Log4om I get the message: "couldn't file file resourcestrings.xml"
My configuration: Win 7 prof 64. Any ideas? Thanks 73
Hi dear friends problem solved!
In my computer I have to accounts, 1 with admin privileges and one as user for daily use. Porgram installed as per instructions as admin. Now when I open it as admin no problem, I have to heavily read the manual though 73
I wonder in case to avoid every time to run as admin and enter password, if there is an automated solution for this 73
