Missing Special functions into CAT config
ON7KZ
Post by ON7KZ »
Congrats, great work but,
If I use double klick into cluster window for switching the TRX frequentie from CW to SSB and also at the same time to a other band I have a schift from 700Hrz this is what happens into V1 if I set the option "Send FREQ before MODE" I can not find where I can change it into V2
my rig FTDX101
Thanks on7kz
Re: Missing Special functions into CAT config
i'll check that.
FWIW - I've tried several changes with double-clicks on spots in the cluster window (F8).
Changes to new band/frequency and mode and lines up with frequency noted in the F8 Cluster.
I'm using a K3 radio with CAT control via OmniRig.
I can't seem to repeat Luc's noted issue.
ON7KZ
Post by ON7KZ »
these is a typical problem with Yaesu, I have a Ft-847 FT-1000 and FTDX101
all of these give the same error
Example: TRX is on 3510 into CW double click in cluster window for change to 14.250 SSB
the TRX is going to 14.243 the difference is the pitch for CW.
A second double click on the Freq. place the TRX correct on Freq.
In V1 I can simulate that with setting the flag "Send Freq before MODE"
greetings
Luc , ON7KZ
ON7KZ
Post by ON7KZ »
issue with CAT for the FTDX101 can be solved to SET into CW menu "direct frequentie" not pitch schift
greetings Luc, ON7KZ
