LOg4om and JT-alert
Re: LOg4om and JT-alert
Post by G4POP » 09 Feb 2014, 22:18
No you don't need DM780 JT Alert will forward anything logged by Jt65 or WSJTX directly to Log4OM providing you enter the correct information in JT Alert
I have been testing JT Alert for the last couple of days and it has worked flawlessly in fact I have just added a new JT Alert section in the user guide
NS2R-Phil
Post by NS2R-Phil » 10 Feb 2014, 15:50
Tnx, It's been a very frustrating experience, but maybe someday I'll figure out why it doesn't work. I tried with the firewall and virus protection off. I also scanned with malwarebytes which didn't find any malware. I set and reset jt-alert to work with log4om many times. it's probably just a fluke on my machine. Tnx Agn...Phil
Post by G4POP » 10 Feb 2014, 16:12
Phil,
Speak to me on Skype from the machine on which the programs reside
NS2R-Phil
Post by NS2R-Phil » 10 Feb 2014, 20:40
Terry, I just looked at your manual update; I set it up exactly like you said. I'll set up Skype on my machine, and contact you here when I do, Tnx''..Phil
NS2R-Phil
Post by NS2R-Phil » 11 Feb 2014, 19:26
Hi Terry, I finally discovered why I couldn't get Jt-Alert to talk to Log4om; it was my firewall Zone Alarm . Disabling Z/A is not enough; it can't be running at all. Right now I'm using Windows firewall. If I can configure Z/A so it allows the the 2 programs communicate, I'll post it here. Tnx..Phil NS2R
VK3AMA
Log4OM Beta Team
Post by VK3AMA » 12 Feb 2014, 05:39
G4POP wrote: I have been testing JTAlert for the last couple of days and it has worked flawlessly in fact I have just added a new JTAlert section in the user guide
Before you email me, I am aware that the help file in the current release of JTAlert is out of date with respect to Log4OM setup. I have that corrected for the next JTAlert release 2.4.14
de Laurie, VK3AMA
Post by G4POP » 12 Feb 2014, 07:07
de Laurie, VK3AMA
Hi Laurie,
I noticed your post on your Yahoo group so I realised that you had that in hand
Post by IW3HMH » 12 Feb 2014, 10:03
This is what i like more...
Cooperation between Old Man :)
Good job guys! Thanks!
lele IW3HMH
NS2R-Phil
Post by NS2R-Phil » 12 Feb 2014, 16:16
Hi to All, This is just a follow-up on my last post. I wasn't able to configure the free version of Z/A firewall. The Pro version does have a facility to allow TCP and UDP ports through. I've decided to use the free Commodo firewall; it works very well with Log4OM and JT-Alert,. TNX 73..Phil :D
VK3AMA
Log4OM Beta Team
Post by VK3AMA » 12 Feb 2014, 21:05
NS2R-Phil wrote:I've decided to use the free Commodo firewall
Phil, FWIW, I use Comodo Firewall on my PCs and VMs.
de Laurie, VK3AMA
