import log
lu3aak
import log
Post by lu3aak »
Hello I can't import the logboob neither v1 or the ham radio deluxe. I don't know why, but always appear a advice that confirm to me, that the logbook is not compatible.
thanks in advance
LU3AAK
Luis
VA3AG
Re: import log
Post by VA3AG »
lu3aak wrote: 25 Mar 2020, 17:11 Hello I can't import the logboob neither v1 or the ham radio deluxe. I don't know why, but always appear a advice that confirm to me, that the logbook is not compatible.
thanks in advance
LU3AAK
Luis
Hola Luis, Hace el export de V1 en mode ADIF 3. Haciendo eso Log4OM V2 va a hacer el import sin ningun inconveniente. Proba y avisanos si tenes otros problemas.
Aldo VA3AG
lu3aak
Re: import log
Post by lu3aak »
Aldo gracias por contestar. Hay algo que debo hacer porque sale un cartel Not connected to a valid database
Gracias
Re: import log
Follow the user guide instruction or quick start guide
YOU MUST CREATE A DATABASE BEFORE IMPORTING AN ADIF FILE
lu3aak
Re: import log
Post by lu3aak »
I suppose that I create it but I for all
73 Luis
LU3AAK
Re: import log
You can have a different database for each adif if you wish or just one database for all and use the filters
I have all of the following in one database
G6CNQ (My old call)
G4POP (Current call)
GB4VED (Special)
GB4ASC (Special)
GB4GMF (Special)
