I recently received my WAS award certificate from ARRL. How do I add it into LOG40M?
Howard
AH6TX
gvm920@gmail.com
818-203-5337
POSTING MY WAS AWARD ON LOG40M
Re: POSTING MY WAS AWARD ON LOG40M
Howard,
Have you looked at WAS in the Award Statistics window?
Have you download (detail download) from LOTW with your validated Q's?
Yes. I did. I received my WAS certificate #63301. I just want to have it show up on my LOG4OM software.
I believe I should show up under f3 so that when someone else pulls me up as a contact they can see my awards. If you have other suggestions I would like to see/hear them.
Howard
Howard
Why not post it as your photo on QRZ then anyone looking you up in Log4om will see the award
I understand. If that be the case what is the purpose of the database field/column for?
Howard
ah6atx
Howard
ah6atx
Which data base field column are you referring to?
