It's not a bug... Log4OM sort incoming spot based on the date and time of the spot itself. If a cluster send spots in the future (or in the past, but without reporting date) we have very little options...
You should start thinking that bugs are not always on our side...
Anyway, i've added a check... actually if no date is provided, Log4OM assume it's current date.
If Date+Time > UTC now +6 hours it will move the spot back of 24 hours.
That should fix
Spots from SOTA Cluster in wrong order
Re: Spots from SOTA Cluster in wrong order
