Hi all. Fantastic job on the new version. I am wondering if there is a way to setup a filter on the cluster so that it highlights a country I need to work for the year. This is in releation to the DX Marathon. With version one I was running two instances of LOG4OM. One connected to the radio and the other on a seperate pc. The version on the seperate pc was for the Marathon only. This way I would be alerted when a needed country had been spotted. If I could do it with one instance of the program running that would be great. I was not able to find referance to it in the manual (unless I missed it).
Regards
Chris
VK3AWG
Cluster Filters.
Re: Cluster Filters.
Hi again Guys. Has there been any movement on this issue? Also when I go into Award Statistics (v2) I havent been able to find any reference to the DX Marathon. All help appreciated.
Regards
Chris
VK3AWG
Regards
Chris
VK3AWG
Marathon has yet to be added although you could create it yourself?
I thought that we had covered the date range in the alerts, I will check.
Just checked and we have not included date range in the alerts so the team must discuss that and a date filter for cluster, watch this space!
Awesome Thanks Terry. Great work guys. Stay safe.
Chris
VK3AWG
Chris
VK3AWG
statistics filtered by date range in cluster...
phew... Log4Om is modular enough to handle that, but it's not a trivial request
Digging up an old thread....but the feature would be awesome. Reading the manual I came across this paragraph. "Standard awards like DXCC, WPX, WAC, WAS, Marathon etc are calculated from the standard fields already present so no user intervention is required for those awards."
That makes me think that Marathon is implemented somewhere in the software. Would I be correct?
