LOG40OM and Maria DB
Hello i try to connect LOG40OM with my mysql server DB but its not working...any idea ?
SV8JNL, Panos, Lesvos, Greece
Re: LOG40OM and Maria DB
I created a database from log4om to mysql (MariaDB). i imported my qso.
I would like to know if it is possible to use the same database from ham radio deluxe?
To import your HRD Contacts into Log4om you would need to do an ADIF Export from HRD and an ADIF Import into Log4om. However, you may lose some Data stored in HRD UserDef Fields.
73 de David G4NVB
Thank you for your answer. I know that. But i want to have the same database for both programs . Is that possible? So if someone want to change logbook will loose data? I imported my adif from hrd and qso before 2017 disappeared...
No, that's not possible. Log4om and HRD Databases are completly different and for example they use different Field names.
73 de David G4NVB
Hello SV8JNL (please create a signature with your name in),
i hope you refer to Log4OM V1 (latest is 1.41) and not to V2. V2 can handle only ADIF 3 to import.
If you use HRD free (v 5.xx by Simon Brown) you can´t export to ADIF 3. At the time when Simon
selling the code we are at ADIF 1 or 2.
So please tell us first your version of Log4OM (see HELP/About) and your version of HRD ...
If we don´t have this information we must use a crystal ball but we don´t have one
@ David, as i can see he´s referring to mySQL and not to sqlite. If HRD have an mySQL option
it could be possible i think ... But not shure
Hello Juergen,
HRD does have a MySQL Option, however, the Field Names etc differ between Log4OM and HRD such that in my opinion it won't be possible to share the same Database with Log4OM and HRD.
73 de David G4NVB
I have the latest version of HRD and V2 of LOG4OM.
I would like to know if there is a way to work them together.
Or if i have log4om sa my main logbook to send the qso with forwording to ham radio deluxe.
