Brilliant. I will modify my adif file.
I want the end time so I can see how long the qso was. As the start and end date is probably the same in most cases I can do a find and replace to do a the adif. The end time already exists so I'm surprised it doesn't get imported. I guess it's because the date and time are combined in log4om.
Import adif v2.2
Re: Import adif v2.2
Thanks Steve M0ZEH
You can't import an end time if there is no end date to match it to
Make sure the field titles are exactly as in the ADIF link I supplied
You can't do a find and replace on a field that does not exist you will need to add those fields
I now have a .csv file with all the columns required. I can't find a way of converting the .csv file back to adif. I don't have Excel only open office which is what I used to make the .csv file. Do you know how I can convert a .csv file to adif?
Thanks Steve M0ZEH
You will need to find an online converter, some are good and some rubbish so check the results carefully
There isn't one. I've been sesarching all morning. There are some that use Excel but I don't have that.
Thanks Steve M0ZEH
Hi Steve
You can try Adifmaster
http://www.dxshell.com/adif-master.html
Separator must be ";" or ","
In settings windows..Select your separator
Import your file *.csv
Then save it as Adif file
73 Philippe
73 Philippe
Thanks Philippe,
I have that one installed alreay thanks. I am now writing an application myself which I will share if I get it working. I have created an adi file ready for importing to log4om. My application reads the hrd 5 .mdb database and converts it to .adi. The hrd .mdb file has time off and time on which contains a date as well as a time so I am using that date to make an adif file version 2.2.3 with time_on, time_off, date_on, date_off. This will give me the duration of my qso.
Thanks Steve M0ZEH
Hi Terry,QSO_DATE
QSO_DATE_OFF
Time_ON
Time_OFF
Why do I get the error on import? See attached error log and adif file.
The time and date in the error log is missing!
- M0ZEH Logbook 1a.zip
- (497 Bytes) Downloaded 182 times
- log.txt
- (320 Bytes) Downloaded 180 times
Thanks Steve M0ZEH
