I am looking for some help beacuse I found a wrong information in cluster. I explain:
I never worked 9K (Kuwait) on 10 M CW as I show you down:
But Cluster show me that:
is it correct?...
Jose EC6DX
Cluster wrong info
Cluster wrong info
EC6DX Balearic Islands
Re: Cluster wrong info
I continue giving you some samples:
I haven´t Russia confirmed by Paper QSL in 40 M:
Could be something about band plan?...
I wish some answer
Jose EC6DX
I wish some answer
Jose EC6DX
I understand, if anybody answer my post, that all of you has a perfect Cluster information... isn´t it?...
Really extrange... I checked all settings ...
Could be something about band plans???...
I can offer more examples...
I hope any news.
Jose EC6DX
I hope any news.
Jose EC6DX
Not bandplan send a support request to me by EMAIL see how here
https://www.log4om.com/generating-a-support-request/
Check the 'Include ADIF' check box
Actually the green band visualization indicates that you have 40m CONFIRMED (any mode) with the country, by QSL and the green mode indicates you have CONFIRMED (CW) (any band)
So this QSO counts for DXCC CW and DXCC BAND
It's not showing the situation of that specific band (40M+CW+QSL RECEIVED)
Doing that is possible, as i have the info in the statistics, but i need to identify a "clear way" to indicate that situation.
Suggestions appreciated
Daniele IW3HMH
Daniele IW3HMH
Hello OMs,
It is correct that the 40M line in green is to confirm the DXCC in any Band, but it should not come out as I work and confirmed a Band that never had a QSO.
In the first example, with Kuwait, I have never worked on 10M CW and it appears in Green. It should appear as for example USA in the line below ... Worked but not confirmed with QSL.
In the second example, it says that I have it confirmed by being in Green on the right side but you can see how in the statistics I have only marked "QSL's" ...
As you can see in the first example, in some situations, it does well, but in others it confuses concepts.
Best 73 de Jose
Best 73 de Jose
