How do I keep Omnirig from turning Ci-V transceive off.
My Acom 700S amp needs Ci-V transceive on to get band data from my Icom 7300 but it is turned off every time I start log4om. Is there a way to prevent this?
Re: How do I keep Omnirig from turning Ci-V transceive off.
I think if you look at the 7300 omnirig ini file you will see the command turning it off is in there and you can edit the commands yourself.
However I beleive that it is necessary for it to be off for CAT control?
Cant you use the ATU or ACC sockets to connect to your amp?
Commenting out that setting in the .rig file fixed the problem. The REMOTE port is used to talk to the amp. You have to set CI-V USB Port > Unlink from [Remote] so that both the remote port and the USB port can be used independently and CI-V Transceive needs to be on.
All is good now. Thanks.
Hi!
The same was situation for me. On ICOM 7300 default settings for CI-V Transceive is ON. It is nesessary for working communication via remote port. In my situation EVERY software, using Omni Rig stops my amplifier to communicate with the radio. I think, this has to be corrected by Omni rig autor. Now my Omni turns CI-V Transceive in On by this changes in IC 7300 ini file in C\Program files (x86)\Afreet\OmniRig\Rigs
[INIT2]
;Turn CI-V transceive ON
Command=FEFE94E0.1A050071.01.FD
ReplyLength=16
Validate=FEFE94E01A05007101FD.FEFEE094FBFD
[INIT2]
ReplyLength=16
GREAT !!!
Thank you LZ2FP for the solution that bothered me. I use the CI-V ON (IC-7300) to automate my Antennas by Frequency and it was constantly OFF and I didn't know what it was.
Thank you very much
73´s PY5CV Brazil
Thank you very much
73´s PY5CV Brazil
