What is "CLUBLOG CALL EXC"?
Log4OM version: 2.10.0.0
User Manual: Updated: 18/12/2020 7:17 PM
Mike / KA4CDN
CLUBLOG CALL EXC
Re: CLUBLOG CALL EXC
Have searched the whole manual for that string and not find it. Can you tell us the
side of the manual or where did you see that string in the menue ?
As a software developer, we can download the entire ClubLog call exceptions and prefix lookup data. This is encouraged as one of the driving reasons for Club Log's existence is to increasing logging accuracy. We use this file as one of the tools to define the accuracy of call lookups.
If your not aware of the great Clublog system see https://clublog.org
Log4OM user guide updated, see page 30 and 50
Juergen ,
It just showed up on the main screen, under the End field. With things like [QRZ.COM], {WKD SAME MODE], etc.
Hello all,
So I now know what the meaning is, but I have this recurring problem.
I am using Log4OM 2 v.2.14.1.0
I attempt to log a portable station who is licensed in and operating in Australia. The Name is returned okay, but I get the message CLUBLOG CALL EXC message, plus the Country returned is Lord House Island #147. Even if I change the country back to Australia and add the appropriate WWFF reference, Log4OM saves the Country as Lord Howe Island (LHI) and drops the WWFF reference.
I can then open the saved entry and again change the Country and add the WWFF reference, which then appears to save okay.
It is a pain!
Callisign where this behaviour is seen is VK2BYF. Bob was on LHI for one week in late April.
How can I stop this behaviour?
Regards,
Peter VK3PF
It is a pain!
Regards,
Peter VK3PF
As I have been puzzled by this behaviour, I went looking at ClubLog.
Using the ClubLog Call Tester tool, it correctly maps VK2BYF/P to Australia.
Yet if I go to log VK2BYF/p or VK2BYF in Log4OM2, it maps Country to Lord Howe Island.
This suggests that the behaviour might be an issue in Log4OM?
Puzzled.....
Cheers,
Peter VK3PF
Puzzled.....
Cheers,
Peter VK3PF
Almost 3 weeks and no response. Very helpful - NOT.
Especially as Bob VK2BYF does a lot of Park activations in VK2, so every single contact needs to be reopened after it is logged and the Country manually changed to Australia, and then the WWFF and other References added again because it does not correctly register when you first add the corrections before hitting SAVE - the program overrules the correct information which I have input, all because of a Clublog EXC which should only apply for a single week of offshore activity on Lord Howe!
Dumb!
Peter VK3PF
Dumb!
Peter VK3PF
Peter,VK3PF wrote: ↑21 Jul 2021, 12:41 Almost 3 weeks and no response. Very helpful - NOT.
Dumb!
Peter VK3PF
This has been looked into and is an item that is still being reviewed. So sorry for your frustration.
I just looked at the Clublog Exception file that was updated July 21, 2021 and the call you noted (vk2byf/9) does resolve to Lord Howe Island. There is a start date of that exception of April 24, 2021 with no end date.
Now, until some clarity can be provided with respect to the data we download from Clublog ... you can go into: Settings / Configuration / Info Providers / Configuration and "untic" the box labeled "Use Clublog data".
I've done some initial testing of that selection (or non-selection as it were) and the vk2byf call then does resolve to AU.
Give that a go to see if it will help you in the meantime.
Nolan,
VK2BYF might have been operating /9 on Lord How in April, or possibly not. As you indicated, that would be a discussion to have with Clublog. Whether he was there or not however, it seems that the call VK2BYF, without the /9, should still show as Australia in Log4OM. They are two different calls, and should be treated differently. Just my thoughts.
Jim N6VH
Jim N6VH
Please be aware that the clublog exception file, that Clublog provided for download and use by external software like Log4OM, does not always contain exactly the same date as provided in the Clublog call tester service on their website.
