I'm running a Yaesu FTdx-5000 controlled via Omnirig.
From the CLUSTER screen it takes double click to QSY to the QRG of the desired station. A single click gives no response. (That may well be "as designed".)
I'd like a single click to initiate the QSY, consistent with other apps such as N1MM+.
QSY via cluster window
Re: QSY via cluster window
Single click puts call in LOG4OM main form. Double click causes CAT QSY. Has been that way since early V1.
K0HB wrote: ↑16 Feb 2022, 04:42 I'm running a Yaesu FTdx-5000 controlled via Omnirig.
Thats as designed
G4POP wrote: ↑16 Feb 2022, 08:19K0HB wrote: ↑16 Feb 2022, 04:42 I'm running a Yaesu FTdx-5000 controlled via Omnirig.
Thats as designed
Thank you for confirming that it is working as designed.
I'd like the design to change to a single click, consistent with other popular apps.
Thank you.
This design was chosen by the users at the inception of Log4om so it's unlikely to be changedK0HB wrote: ↑18 Feb 2022, 04:43G4POP wrote: ↑16 Feb 2022, 08:19K0HB wrote: ↑16 Feb 2022, 04:42 I'm running a Yaesu FTdx-5000 controlled via Omnirig.
Thats as designed
Thank you.
Single click = Look up call
Double click = Lookup and QSY
As detailed in our user guide
