How can I do this for clusters preloaded with Log4OM install? I want to eliminate the sh/dx 30 at that shows latest spots for 30 meters and not the last 30 spots. Also want to get rid of the password line since that causes connect issues with some clusters.
Ron
N4XD
Edit cluster log on script
Re: Edit cluster log on script
Ron,n4xd wrote: ↑09 Mar 2022, 17:47 How can I do this for clusters preloaded with Log4OM install? I want to eliminate the sh/dx 30 at that shows latest spots for 30 meters and not the last 30 spots. Also want to get rid of the password line since that causes connect issues with some clusters.
Ron
N4XD
Go to: Connect / Telnet Cluster / Connection
You can edit the clusters you have chosen to operate in Log4OM V2. You can comment out the items you want and/or removed those items.
Image below is representative of a cluster I engage now and then and some active commands.
- cluster-management-medium.PNG (68.81 KiB) Viewed 925 times
Thanks.
It could be just me but the editing process isn't immediately obvious. It appears that first, you must remove the cluster from the active servers list. Then edit it in the known servers window. Then once again choose it. I would have thought it was possible to do the edit by clicking on the cluster in the active servers window.
I guess the hint is the location of the icons (plus, new, write etc ) all being alongside the known servers window.
Ron
Ron
Ron,
That is correct ... you have to disconnect the connection. Remove the cluster from the lower left panel. Then you can edit that cluster, save and then add again to the lower left panel.
Download the "current" User Guide (dated: 18/02/2022 10:31AM )
Discussions about the Telnet and Clusters starts on Page 66.
