Problem with TS 2000
F4BVK
Post by F4BVK »
Hi there
I managed to configure My TS2000 with LOG40M, JTDX, JTALERT, and GRIDTRACKER.
Everything works perfectly, because I receive all the signals.
The problem is that I have the TS2000 which automatically switches to FSR mode, whether in reception or transmission. And when I want to send this one automatically switches to FSR, hence impossible transmission.
What is the problem ?
Thank you for your help
F4BVK cedric
F4BVK
Re: Problem with TS 2000
Post by F4BVK »
I bring up the subject
No help, namely that I use a SIGNALINK as an interface and as a control cord for the TS2000 A USB-63 CABLE.
All very well with HRD DELUXE but I have this problem with LOG40m.
F4BVK Cedric
F4BVK
Post by F4BVK »
It's good I found. It was all in the JTDX configuration.
You had to set Mode and Split to NONE. (SETTING---->radio)
Completely different configuration than with HRD.
