I have a problem with some worked QSO.
When I click on green [wkd same mode group] text, the Worked before windows did not open.
But when i click grean text [wkd bank mode] in other qso everything work fine, and the Worked before window are opened normaly.
Can you help me and tell me what I am doing wrong?
Version: 2.23.0.0
Thanks,
Artur
[wkd same mode group] not working
Re: [wkd same mode group] not working
Well its working fine here, see image below.
Antivirus, firewall or something local blocking?
WKD SAME MODE and WKD BAND MODE is working OK,
Problem is only witch WKD SAME MODE GROUP and WKD SAME BAND/MODE GROUP.
I noticed that when I save a QSO, the WKD SAME BAND/MODE GROUP changes to WKD BAND MODE and the window already appears.
It's probably a glitch, checking now
I have the same problem.
At this date (11-2022) does not seems solved.
73 Marco I0MOM
73 Marco I0MOM
73 de I0MOM Marco
Marco,
What version of Log4OM are you currently using?
21 dec 2022.
The problem is still on.
Log4om is V2.25.00
Merry Xmas de Marco I0MOM
Log4om is V2.25.00
73 de I0MOM Marco
here the same ..[wkd same Band/Mode Group]Green not opened and does not show the QSOs made!
Google Translate
SORRY
Google Translate
![Embarrassed :oops:](./images/smilies/icon_redface.gif)
OE5CCN
Kenwood TS 480 HX 200 Watt Hexbeam 10 Meters over Ground,Most active 20,17,15,12,10 in ALL Modes
OM: Christian
Salzkammergut /OÖ.
Austria
OM: Christian
Salzkammergut /OÖ.
Austria
It still doesn't work but I found a workaround.
Noted that "wrk same band mode" without being able to browse previous QSOs happens on digital modes if You worked the station in RTTY or FT8 and now the spot was on a FT4 mode.
I simply cut the station callsign, change the mode (eg FT4 to FT8) and reinput callsign.
This time shows WRK SAME MODE and I can browse previous QSOs.
Until It will be fixed I think It's OK!
73 de I0MOM Marco
73 de I0MOM Marco
73 de I0MOM Marco
