hello,
For the 230° anniversary of the Vaucluse departement, we activate a special call throughout the month of June.
The code will be composed of TM84VA, then TM84UC/LU/SE in order to reconstitute the word VAUCLUSE for the diplome or.
I understood that in Log7OM it was possible to enter the 4 indicators, to use them with a profile for each. What I would like to know if I am to use a database for each, is it possible to have a single log, named for example TM84,which would record the activity of TM84VA, TM84UC, TM84LU and TM84SE in a single database. Just one question, thank you for your answer.
Activation with 4 calls, possible only one log
F1ABL Michel JN24of
Re: Activation with 4 calls, possible only one log
Yes you can use a single log just be sure that qso's have the relevant station call sign recorded by each config
You will then be able to search the single database according to the relevant station call for awards, labels etc
Thank you Terry for your confirmation.
I’ll see to implement it.
73 F1ABL Michel
73 F1ABL Michel
F1ABL Michel JN24of
