I have been using Log4om with my IC-7300 for a long time and with great satisfaction. I recently purchased Win4icom and had to adjust the port settings with the com0com software package. As a result, I also adjusted the port on Omni-rig. Everything works and I am satisfied with it, but there is 1 problem.
If I use Log4om separately, without Win4icom, it sees the wrong port and the CAT does not work properly. Then I have to switch the port back to my original port on my IC-7300 in Omni-rig.
Is it possible to make an adjustment to this? I would like to hear from you.
With regards Fred-PA3ETM
Log4OM in combination with Win4icom
Re: Log4OM in combination with Win4icom
Hi Fred, I also use Win4Icom, Omni-rig and an Icom transceiver. If you would like to send me a detailed email, with all your port settings, I can make some suggestions. Email me at my QRZ address.
73 Bill WT0DX
73 Bill WT0DX
Thanks Will and I make a document with the info. I found you on QRZ.
