As in version 2.32.0.0. and previous versions, I notice that you regularly lose the connection to your SQLITE database.
However, everything is correct in the configuration.
See Configuration > User Configuration > Station Information > Database. There it says Database = SQLITE and the path is
C:\Users\name\Documents\LOG4OM2\ON6AT.sqlite
After I have been active for about 2 hours, I see that the log is no longer updated.
The filtering also no longer works. THIS way I know that the DATABASE sqlite has stopped working.
I always have to consult the backup and restore everything.
This is very annoying.
How could it be that you keep losing that database link?
73's de ON6AT Patrick
Lost Database - SQLITE V2.32.1.0
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
Member UBA-IPA
WCA: ON-01354
