It would be convenient if the option was available to automatically upload each QSO to EQSL as it does to Clublog and others.
Gerry/Ei9Ju
EQSL - Resolved
Re: EQSL
Hi Gerry,
It will auto upload each QSO as the QSO is saved for eQSL, HRDLog and Clublog but not LOTW due to overloading the LOTW server during contests - eQSL works fine automatically.
Terry
Terry
Re: EQSL
Then it should work here too.
I just thought this option was not included as it is not appearing as for HRD or Clublog.
I just did not add any new QSO since I started to use Log4OM some weeks ago.
As soon as I'll have moved in my new house in March and have set up the antenna I'll check this
73 de XV9Q Greg
Re: EQSL
I always thought I had it enabled but recently I've been getting requests from eQSL users, when I checked I haven't uploaded a single QSO since I started with Log4om.
I've got Settings; Options; External Logs------and the eQSL ID and password entered, the box for automated upload has also been ticked.
I'll need to investigate it further at my end Terry, maybe the password is missing a character or something.
BTW, I've also had the Clublog settings activated from day 1 and they've been going through no problem.
Gerry
Gerry
Re: EQSL
I have not been able to get it to work either. I've checked the user name and password. Also, the upload (or download) from the QSO manager does not work for me. It says 'done' on the download but nothing shows.
When I checked the log file, it indicates bad username/password but I'm pretty sure they are correct (I logged out and back in to the eQSL site to verify).
I had concluded that you needed to be a paid member of eQSL (bronze, silver or other level?) to use their site with external programs. I did not read anything about that in the Log4OM manual or anywhere online but might that be the issue?
Also on a similar thread, is it possible to log or upload to QRZ.com as well?
Thanks.
Mike
Installed just yesterday and while it has taken me a bit to figure it out I am warming up quick to it.
Thanks.
Mike
Re: EQSL
I'm still having an issue with EQSL upload, like Mike KA4CDN, I've doubled checked username and password info but still can't get it to work through Log4om, using the same username and password I can upload using the EQSL site.
Gerry/Ei9Ju
Gerry/Ei9Ju
