Hi
i've made some changes on the automatic reference identification
Now i'm able (must be fully tested by our beta team) to identify a reference also if not connected to the main string:
as example:
DCI-1000 is now recognized also when set as: DCI 1000
On some awards like spanish "diploma municipios" DME the code set in Log4Om is only numeric (eg. 10001)
This was not recognizable with automatic routines before.
Also, with previous version DME-10001 was not recognized, as reference was only 10001.
now i'm adding the award prefix if it's missing in the award definition, so a spot with DME-10001 will match the 010001 in the DME database.
I've also added automatic SOTA recognization from cluster
Updates in next 1.21
Moderator: OE6CLD
