Since last update to version 1.22.0.0 each time I start Log4OM it pops up with message dialog saying:
"Error while loading SCL fileThere is an error in XML document (0, 0)"
After I close that dialog Log4OM loads properly as there was no error.
If I close log4Om and start it again error message does not popup. Then again on some next start, it pops up again.
This did not happen before update.
What could be the cause?
Re: Error while loading SCL fileThere is an error in XML document (0, 0)
have you tried doing a manual update of the SCL file
I could try if I know what it is.
Pedja,
Log4OM Settings>SCL Database>From K7PT Web Site
It seems an error while downloading the xml file...
Now error does not popup so I cannot test ![Sad :(](./images/smilies/icon_e_sad.gif)
I guess it stopped popping up after you updated the SCL file
Actually it stopped with no update.
Any info in the logfile?
