I did select Activator, and also i did update SOTA files.
Problem is that country list contains only countries that are in SOTA.
When I activate location I have contacts with countries that are not in SOTA. Those counties are not in a selection list so such contacts cannot be included in report.
What is needed is option to make selection which does not count country info at all.
It seems to me that you cannot reproduce problem as you do not have appropriate log data. If you need it, i can export my log data and send it to you to try out.
How to export SOTA activator log to upload to SOTA site?
Re: How to export SOTA activator log to upload to SOTA site?
I asked for your log several posts ago, yes send me an ADIF!
I missed that request. I've sent it now.
I received your ADIF file, created a new database and imported the ADIF file
All 70 QSO's displayed correctly and the SOTA activator export worked fine as demonstrated in this YouTube video
https://youtu.be/Pkb5iZ3BjOQ
Thanks for your effort.
That is exactly how I did it and I got 52 of 70 records. I noticed that after I uploaded file to SOTA database and saw statistics there.
However, after I noticed error, while checking out I did not go to export option but simply, when I get list of activations I click on W in that list to check records. You can see 52 instead of 70 records there. When I saw here wrong number of records I did not go to export as it seemed pointless.
However, now I did go all the way to make export and indeed this time I got all 70 records in export.
In statistics, it still shows only 52 of them.
This is not the method described in the user guide or the two earlier tutorial videos that I provided.yt9tp wrote:I did not go to export option but simply, when I get list of activations I click on W in that list to check records. You can see 52 instead of 70 records there. When I saw here wrong number of records I did not go to export as it seemed pointless.
Export is correct but the list has a bad filtering.
Fixed.
Thanks for reporting Pedja.
Fixed.
Great Daniele!
