So how can I change the band on my rig?
Right now I need to physically click the Band up or down buttons which is kind of annoying...
Fldigi not changing freq
Re: Fldigi not changing freq
Possibly the best option for you would be to use a virtual serial port emulator
One end of this virtual cable is the com port the radio is connected to e.g. Com 3
The other end also has a com port number e.g. Com 18, to which yuo can connect up to eight software programs to
Connect Log4om to the VSP port 18 using Omnirig
Connect Fldigi to thecVSP port 18 using Hamlib or Rigcat
Now everything should synchronise
To get the QSO's logged in Fldigi to be sent to Log4om use the ADIF facility in our communicator
Ok.
Thanks a lot.
I'm using serial port splitter for all.
Thanks a lot.
