Any chance?
I still can not assign any award to the contacts. I'll have to go back to the DXlab until I find a solution.
Many thanks and 73.
Don´t have awards
Re: Don´t have awards
Are you running Log4OM with Administrative Privileges?
Yes Chuck.
I have been working with the program several years without any problems and since the update of windows 10 to windows creator, literally "the awards have disappeared".
Thanks and best regards
Victor,
It appears from what you say it happened as a result of the update to Windows Creator.
Could you do a restore of your system to before the update and see if it then works? It would be a big help to us if you would/could do that and let us know the result.
It could be the "new security feature" contained in the update to Windows Creator.
Can you download updates to the SCL and other files from Log4OM settings drop down???????
BTW: You may want to read this as it seems there are big problems with the update:
https://www.theregister.co.uk/2017/04/2 ... rs_update/
From the article: "That Microsoft is calling for a halt to manual updates so soon suggests there are still irritating bugs in the code to iron out."
Thanks in advance.
Thanks in advance.
Still waiting for you to email me re team viewer?
Again my email is G4POP (AT) arrl.net
Still no email received so I am not able to assist this user at this time
In that case download log4om in portable mode, find the activations .sqlite file and replace your own in the settings folder.
This fix any corruption of the database file that could happen (then re-download the updates...)
¡¡¡YESSSS!!!
It was a problem with the file activations.sqlite.
In W10 the file is in...
C:\Users\ec1ai\AppData\Roaming\LogOM
Where "ec1ai" is your user
Many thanks, I can go back to work with Log4OM
Víctor
Víctor
