ic-7300 CAT problem- delay
Re: ic-7300 CAT problem- delay
sq7bcn wrote: 25 Sep 2017, 14:47 Ok please email address ...
I already said g4pop (AT) arrl.net
(AT) is @ I don't write the email like XXXXX@XXXX.com to stop spam
sq7bcn
Post by sq7bcn »
VA3AG wrote: 25 Sep 2017, 15:16
sq7bcn wrote: 25 Sep 2017, 05:47 I'm using Omnirig, changing to administrator rights has not improved.
The bitrate is 19,200 because only the trx connection is set up just as the rest of the settings(bitstop etc) are correct as in other programs Loger32, JTDX, WSJTX- work properly.
You need to set your radio to 115.200 baud rate.
No in IC-7300 is only 4800,9600,19200,Auto I set 19200.
sq7bcn
Post by sq7bcn »
I think the problem is in Rigs file Icom 7300.ini
Loger 32 have the same setings com, baudrate , stop bits ,polling int.=1000ms etc.)and work fine.
VA3AG
Post by VA3AG »
sq7bcn wrote: 25 Sep 2017, 19:40 I think the problem is in Rigs file Icom 7300.ini
I have mine set for 115.200 baud rate and it connects just fine, at 19.200 baud rate mine did not work.
Good luck!
Aldo VA3AG
sq7bcn
Post by sq7bcn »
Ok
You have set:
CI-V USB Port - UNLINK from Remote
CI-V USB Baud Rate - 115200
CI-V Baud Rate - 19200 it probably doesnt matter ...
We have many users that have the 7300 working fine with the 7300.ini so it has to be something local on your computer set up.
I still have not received the Support request with 'Trace' mode activated ??????????????????????????????
sq7bcn
Post by sq7bcn »
Ok Terry I send correct support file.
Today I have change baudrate for 115200 CAT not working (Red Lamp) 38400 the same problem .
19200 work - very unstable -not for work.
I checked WSJT-X program for 115200 work fine.
Maybe the 7300.ini file I got some bad or old because therewas no file in the instalation file to 7300.
sq7bcn
Post by sq7bcn »
Problem has been solved.
I removed the driver from the computer, restarted my computer and reinstalled the same driver - it helped.
I did not do this before because the rest of the programs worked properly - that made me wrong.
Sounds like my email suggestion to you
Did you install the genuine ICOM USB driver before connecting the radio? The Windows driver will not work properly with the ICOM 7300
The USB driver has been an issue with all of the latest series of Icom radios especially if you connect the radio and then try to install the Icom driver or worse still let Windows install the driver automatically
sq7bcn
Post by sq7bcn »
The driver was installed correctly and did not show problems with 3 other programs so I assumed the problem was elsewhere.
Your suggestion Terry helped me with this topic - Thank You.
