WFF list out of date
Moderator: OE6CLD
VK2YW
Re: WFF list out of date
Post by VK2YW »
Sorry ..just saw Gerard's reply ..might try manually in the meantime.
John VK2YW
I will ask for an updated list from the WFF team in ITA.
Next release (1.23) will have a new button in QSO management / Field Update to FIX references, adding or removing leading zeroes according to the current award informations in the database.
Function will be in the Log Check-Up area, under "Check for updated award references" flag
So if the reference is WFF-VE0100 and you have WFF-VE100 the record will be fixed, and vice-versa.
Will be released under "New function that rescan log to find orphaned award references and reconnect with the correct one "
vk2io
Post by vk2io »
Thank you for the updates in 1.23 for WWFF.
Unfortunately the WWFF awards database is out of date. I have not been able to test the improvements yet.
Every month there is a new WWFF directory posted here: http://www.dcia.it/iffa/images/download ... ectory.zip
The problem is that it must be manually processed before we can update log4OM, and this isn't happening (last one was in July).
It would be great if Log4OM could import the official file directly, and then we could update every month.
Do you think this would be possible, Daniele?
Cheers,
Gerard - VK2IO
I'm in contact with the site admins, they usually send me a txt version on request.
I'll ask them an update.
Automatic update is easy to do, but unfortunately not from a PDF file like the one you linked there.
vk2io
Post by vk2io »
Thanks, Daniele.
There have been many additions to VK recently and of course the new ones are the most popular to activate.
Would be difficult to process the PDF. Perhaps WWFF folks would put the text file online for everyone.
Cheers,
Gerard - vk2io
This is what i've asked for :)
They're usually really fast answering.
I think we can update soon the list
WFF Database updated with december 2015 references
VK5PL
Post by VK5PL »
There have just been another 136 VKFF references added in the last day or so and I made a CSV file and tried to merge it with the WFF file existing and they all appear in the awards manager, but do not appear in the award drop down when entering a QSO. It is something to do with the dates valid from/to, because a couple of references that were incorrect and I deleted and reentered manually, DO appear in the QSO dropdown list.
Any ideas? I think I have had this problem previously and was fixed by not having dates in the CSV file, but then the new references will have the same Valid from/to dates but they should only be valid from today.
David
VK5PL
David
VK5PL
Did you check the 'Merge' check box?
VK5PL
Post by VK5PL »
Yes I did tick merge and they all appear in the centre tab on that page (Award References) but not in the drop down when entering a QSO.
ps added a bit more to my post above.
David
David
VK5PL
