Log4om Version 1.19 now includes support for the K1EL Winkeyer, all versions including the latest Winkeyer Version 3.00 and above.
Direct logging from the Winkeyer control window with full contest logging support is provides and in the coming weeks extra features will be added.
The save and load facility in Winkeyer support enables users to create and recall any number of different macros - Rag chewing, Contest specific,run and S&P macros etc etc
The program can be downloaded from:
http://www.pisto.it/wordpress/log4om-en/
English and French user guides can now be downloaded when using the Log4om installer or directly from the link above.
Fifteen YouTube Log4om tutorial videos are available at:
https://www.youtube.com/channel/UC6Ppcj ... yavI-azOug
This release still requires the old version to be uninstalled before the new one is installed
Other Log4OM enhancements include:
• New cluster spot lookup without QSY
• Added French version of user manual
• Automatic user manual download during install
• Option to install Omnirig during Log4om installation
• SOTA Summit list automatic download added
• Added an option to ignore CAT updates from rig for manual data entry
• New Import and export of user awards from/to XML files
• Lock QSL Message text function added
• Added SAVE AS button to File menu to create a copy of SQLite database
• New QSO DATE/TIME update implemented with +/- time edit to QSO Archive Manager
Fixes
• Added extra lines to NOTE field
• Upload to HRDLog now includes COMMENT field
• Deleting the awards database no longer removes user-defined awards
• Incorrect sort for JT9 mode list resolved
• Crash in small cluster view under some circumstances now resolved.
• Increased the separation between the ADD and Cancel buttons in main User Interface
• Import of SRX and STX ADIF fields modified to work with corrupted ADIF files
Log4OM 1.19.0 released
