WCA
Moderator: OE6CLD
Re: WCA
Obtain the list from the award organiser as a spreadsheet or CSV file, then you can format that file and import it using the facility provided in the award manager - see the user guide for instructions
Alternatively when you have obtained the list send it to Claus our awards coordinator and ask him nicely if he will do it for you
Re: WCA
Attached is the WCA award
1. Unzip the file
2. In the Log4OM award manager (Utilities/award manager) click the "File" menu at the top left corner
3. select "Import award from xml" and select the file that you unzipped earlier - Click open
4.close the Award manager window
5. Open the award manager window again and check the "World_Castles: Worked World castles Award" is in the list
You are now ready to start working and recording the WCA award
Thanks to Chuck for his hard work in compiling this award
1. Unzip the file
- award_WORLD_CASTLES.zip
- (742.06 KiB) Downloaded 101 times
- Location: Höhr-Grenzhausen, Rhineland Palatinate, Germany
Re: WCA
Checked that way and import works fine for me ....
A big thank´s to Chuck too for his work
Re: WCA
Added WCA also on main software update functions.
Unfortunately it's complicated to upload to website (because of his big size) so our award manager should pass file to me for updates
Re: WCA
I'll ask Claus to check that.
In the meanwhile there is an "useable" reference list somewhere that could be used? This could greatly improve our responsiveness in awards management (Claus is handling an huge amount of awards!)
