First you have to design a Grid Square Award (GSA) with the Award manager. Maybe one like
this: http://www.wia.org.au/members/wiadxawards/gridsquare/
If you do so (hard work with 32400 Grids) you may also aktivate 4m band for it ( there´s no
official award yet that includes the 4m band).
With no GSA in the award list you can´t check how many Grids you worked at 4m.
To have an oversight on a map you may use a grid tracker site. You can export an ADIF from
Log4OM QSO manager and load it up to the site. Than it mades a map for you with your
worked and confirmed (red or green) grid squares. But it´s only a map without a count of
the grids.
http://wg7j.reinalda.net/gridmapper/gridmapper.php
Statistics and Awards Questions
Re: Statistics and Awards Questions
Thank you. I thought so, but I have a problem creating an award. I do everything as described, but when I try to write, I get the message:
73, Robert SP8SN
Looks like you not have the modes selectet that are valid for this Award.
It´s right beside the band selection box.
In a later step you also need all the grids as references in the references tab.
