Cluster Scanner Tab jitters badly with vertical scroll bars
w6trh
Post by w6trh »
As many have said, thank you for a great product and for always making it better.
I was using the Cluster Scanner tab during a recent 6m band opening, and I noticed that whenever the number of spots exceeds the size of the scanner boxes that a vertical scroll bar appears. That in and of itself is okay, except that whenever any of the cluster boxes have a scroll bar then all the scanner boxes appear to jitter badly. I am using v1.22.00 with Omnirig v1.15, and windows 7 ultimate.
Thank again for a great product.
Tom
W6TRH
Re: Cluster Scanner Tab jitters badly with vertical scroll bars
Are you experiencing a situation where the number of calls in the same box is higher than provided space?
well... it's really rare, but i will check with case. Thanks for reporting
w6trh
Post by w6trh »
That's was exactly what I experienced. In fact I also think that many of the cluster spot boxes were full beyond what could be displayed, resulting in several boxes being full and having vertical scroll bars.
I am guessing here, but it was like the spots were very quickly moving between the boxes, even though I was not turning the VFO knob on my rig.
I agree, this is a rare occurrence.
Where you using a skimmer cluster?
w6trh
Post by w6trh »
Terry,
Honestly, I don't know. How do I check this ?
Utilities/cluster what is the name of the cluster in the box at top?
w6trh
Post by w6trh »
Terry,
Yes, I am using a cluster/skimmer.
It is ve7cc.net:23
Tom
That is what is causing it
At times when there is a contest, DXpeditions or a lift on six meters there are so many skimmer spots being received is a very short time that the computer program can't display them fast enough.
It might help to make sure that in the option/cat & cluster tab that the box marked show un-grouped is not checked
You might also set the VE7CC cluster to filter out unwanted spots to reduce the volume of incoming spots
I'm currently on this issue
w6trh
Post by w6trh »
I experienced this issue again with 1.23.0.
Maybe one solution is to not add redundant entries to the frequency/spot boxes. In other words, if a callsign is already in the box, don't add it again.
Thanks guys ! ! !
