Is there a way to select a different cluster? I am use to using VE7CC telnet and have my filters set there the way I like them. I don't see anyplace to change whatever the default cluster is.
Tnx and 73
Greg
DX Clusters
DX Clusters
Greg - AB7R
Caldwell, ID
Greg - AB7R
Caldwell, ID
Re: DX Clusters
AB7R wrote:Is there a way to select a different cluster? I am use to using VE7CC telnet and have my filters set there the way I like them. I don't see anyplace to change whatever the default cluster is.
Tnx and 73
Greg
Greg,
Utilities/F3 and then click 'Disconnect'
At the right hand end of the cluster name field there is a drop down arrow, click it and select a new cluster
Click 'Connect'
If you need to add a specific cluster to the list see page 33 of the user guide and edit the cluster list
