I have Dropbox set up and working to sync my logbook across different PCs, but I was wondering if I could do the same with the settings?
Settings like online logging account and password settings, column views and widths I have set up, saved searches for the filters, cluster personalisation (ie what bands it shows spots for) etc?
Looking at the manual dated 02/02/2015 5:16pm, page 154 item b) it looks like I can extract the settings, but can I tell Log4OM to use a shared dropbox folder for this?
On Settings/Settings 1 tab I can see a "View Config Path" button and options for backup folder, which I assume are related, but can't see a way to tell Log4OM to use config files in a new location.
can I sync program settings with Dropbox?
Re: can I sync program settings with Dropbox?
The easy way is to install our portable version in Dropbox then run it from each computer or Windows tablet - That's what I do!
that sounds like an idea. Will I need to uninstall the installed version before using the portable version?
If so how can I protect/re-use the setting up I have done so far?
Steve http://g1ybb.uk/
First install the portable version to Dropbox - Install with administrator privilegesG1YBB wrote:that sounds like an idea. Will I need to uninstall the installed version before using the portable version?
Now copy from your C:\............................\AppData\Roaming\LogOM folder the file named Config.xml
Paste that into the Log4om Dropbox folder called 'Config' and let it overwrite the existing file
You can either remove the program from your hard drive or leave it there until your completely happy with the portable version
that won't confuse things at all?
I find that portable apps generally still make use of the registry despite no install as such.
Eg, I have several versions of Firefox installed hanging around on the HD, but each one will 'take over' the current registry settings, so whilst they are essentially separate installs they share common registry entries and common files.
Presumably also, the portable version has the same functionality completely as the 'installed' version?
I'm just fearful of breaking my now working quite nicely setup.
Unlike other software Log4OM does not scatter entries all over the registry, just one pointer to the program and nothing for the portable version unless you put a shortcut on the desktop
great!! thanksG4POP wrote:Unlike other software Log4OM does not scatter entries all over the registry, just one pointer to the program and nothing for the portable version unless you put a shortcut on the desktop
Re: can I sync program settings with Dropbox? UPDATE
Finally I have this sorted.
Took me a little while to get to setting up the portable version on my main PC. That all worked fine.
But my other test PC at the time refused to connect to dropbox. Or more accurately, the IT admin on the system was blocking it, probably due to poor settings on all the restriction software and proxies in place.
Anyhoo, dropbox came back to life recently.
I got all my actual settings nicely, but as the QSO database was also in dropbox, within default place in user profile documents folder, starting Log4OM on the test PC meant I had no QSOs, until I told it where to look.
Then of course, same thing again when back on main PC, no QSOs, looking in wrong place.
Fortunately Dropbox has a rather painless ability to move the synced folder from options. Moved both to C:dropbox, and all is well with the world.
All I need to do is actually turn on my Surface Pro 3 one day and set it up now.
I actually install the portable version on my Google Drive (same applies to Dropbox) and I store the logbook SQLite file there also.
Everything including my configuration is then always in sync on all of my computers, including my Lynx Tablet
A small note:
Configuration also contains ABSOLUTE PATH to some resources outside the configuration folder.
As an example, where the log file is stored, where you can find TQSL and similar.
So, if your dropbox/Google drive is phisically on the same place on every PC, or you need to manually select the database file/other resource files.
Everything related to Log4OM configuration that resides in /config folder is automatically found on start.
