reglage option qsl
F1TRF
reglage option qsl
Post by F1TRF » 23 Sep 2015, 12:36
bonjour a tous
je suis utilisateur de LOG4OM que j'appréci énormément
j'aurai voulu avoir plus d'info sur le réglage des paramètres de <QSL and Label>
a quoi correspond exactement les 5 options
merci de votre aide
Laurent
F1TRF
Re: reglage option qsl
Post by IW3HMH » 28 Sep 2015, 09:55
Hi Laurent,
those data are the DEFAULT values that will be applied to new QSO saved in Log4OM.
You can change this according to your personal requirements.
F1TRF
Post by F1TRF » 06 Oct 2015, 15:41
ok merci
mais cela ne répond pas a ma question
Laurent
Post by IW3HMH » 06 Oct 2015, 17:25
Ok
There is not a "standard" method to use QSL statuses.
As example, we have those values in the ADIF protocol:
YES
NO
QUEUED
INVALID
REQUESTED
Some users set
NO as default for NOT SENT BUT I SHOULD SEND
YES = QSL sent
REQUESTED = The counterpart has solicited the QSL
Other users (me, as example) use another method:
REQUESTED = i should send QSL
NO = i will NEVER send a QSL for this QSO
QUEUED = i have PRINTED QSL but not sent to the bureau (still in my shack)
YES = SENT
As there is not a "standard" rule, Log4Om let everyone set the defaults as they wants.
All logics are transparent, but DEFAULT works on "my" standard way. If you don't have a preferred way i suggest to follow my way, as Log4OM have already all defaults set for this way.
F1TRF
Post by F1TRF » 08 Oct 2015, 16:13
73 DANIELE
MERCI POUR LES INFOS
Post by IW3HMH » 09 Oct 2015, 16:37
