I used different call signs, and I am using for each different call a separate log (Database)
I would like to include all my logs (Database) in a Archive search, for instance a Call sign.
Is this possible ??
73 Hans DF2MC
Archive search include all Logs (Database) ?
Re: Archive search include all Logs (Database) ?
Hans,
No it is not possible unless you combine all logs into one main log
Do you have a specific need to have multiple databases (logs)? I have a combined log because the filtering in Log4om is so good that I can filter by station, operator or owner call signs to do virtually anything!
I will try your suggestion, perhaps I have to get used to the filtering possibilitys in LOG4OM.G4POP wrote:Hans,
I was using UR5EQF and there it is possible, include different logs in a search.
Scrolling in a large Log was very slow in UR5EQF and many crashes, therefor I used different Logs, for instance Contests-Logs.
I know the Logs are stored in a different way in UR5EQF.
A friend -DJ0FX- how has about 150000 QSOs from 15 different calls, (Pacific DX-Peditions) therefore 15 different Logs.
He asked me how to handle in LOG4OM, would it work like your suggestion as well, combined in one large Log so many QSO`s,
search speed slow down ?
Thanks Terry
73 Hans DF2MC
Hans,
For that number of QSO's he should use the MySQL database, SQLite is OK for up to about 100,000 QSO's
Thank you Terry !G4POP wrote:Hans,
