I'd like to hv Log4om, log my contacts from WSJT-X/JAlert....I found the settings menu in JTAlert but hv had no success in getting Log4om to log my contacts....
Individually all the programs work just fine.....I guess I don't understand how to make them talk together....
Using Flex 6500....Win 10 Pro....PC uses a static IP address
Could use some help please....
Thanks..73
Steve
Log4om connect to JTAlert for logging
Re: Log4om connect to JTAlert for logging
Found what I needed in the JAlert help files.....problem solved!
Let me guess... not running as administrator ?
