Net Control window start time wrong
G4AON
Post by G4AON »
When using the Net Control window, stations that are in the left hand part of the window (active in the net) can be moved up and down the list in order to keep them in the correct "running order"... However, when you move them up or down the list their start times change to the time that you move them, it should be the time they joined the net and were moved from the right window area to the left.
73 Dave
Re: Net Control window start time wrong
Duly noted and added to our Mantis list
