Jump on a spot, and start time for QSO sets immediately
I just noticed that if you are using the setting that sets the QSO start time whenyou leave the callsign field, and you double-click on a spot in the cluster window to set the rig, it sets the QSO start time immediately. It should wait until you tab out of the callsign field. Clicking a spot once to load the field works as expected.
73, Duane AC5AA
Re: Jump on a spot, and start time for QSO sets immediately
Duly noted and added to Mantis
Well, technically it's a field leave...
time stops on each action (field selection) on every field different from callsign. Why cluster should be different?
