In the current version, in order to close a net you have to "right click" each call and wait for it to clear. If you click the "close net" button, it doesn't save the entries.
Can we have the "close net" button also save the entries to the log?
Ver 2, better closing of net?
Re: Ver 2, better closing of net?
The usual method is to drag and drop the net member from the left panel into the right inactive panel as they leave the net, this then results in there just being a couple of stations left as I close the net to be dragged across - I cant remember an instance of having more than a couple of stations left when I close our nets!G4AON wrote:In the current version, in order to close a net you have to "right click" each call and wait for it to clear.
I am sure that this will be possible but not in this version because its on maintainenceIf you click the "close net" button, it doesn't save the entries. - Can we have the "close net" button also save the entries to the log?
