I'm running a Kenwood TS-590SG. Both SDR-Console or Log4OM work well with the TS 590 independently using Omni-Rig.
I can't seem to get the three of them working together. TS-590, Log4OM and SDR-Console.
Any help would be appropriated.
John
SRD-Console
Re: SRD-Console
It works fine if you use Omnirig in Log4OM and SDR-Consul, I use it myself with an IC7600, RF-Space SDR-IP, SDR Consul and of course Log4OM
Omnirig multi threads which enables multiple programs that use Omnirig for cat control to share the connection
Re: SRD-Console
Thanks Terry. Been viewing your Youtube file, very helpful.
To get it to work I've run SRD-Console in administrator mode as well as running WST-X in administrator mode. Saw that in another post, so after your response gave it a go.
Do you have any idea why I would need to run it in administrator mode?
One other question if I may. I use DXSummit cluster, is that able to be used with Log4OM?
Re: SRD-Console
Because Windows is very pickyvk3pz wrote:To get it to work I've run SRD-Console in administrator mode as well as running WST-X in administrator mode. Saw that in another post, so after your response gave it a go.
Yes just find our the address and port number so that you can add it to the Log4OM cluster listOne other question if I may. I use DXSummit cluster, is that able to be used with Log4OM?
