Voice message recordings ?
VE4DXR
Post by VE4DXR »
Hello and Happy Father's Day. I would like to know if Log4OM can record and play my voice cq message. That would be handy for portable. 73. Lee, VE4DXR
Re: Voice message recordings ?
VE4DXR wrote:Hello and Happy Father's Day. I would like to know if Log4OM can record and play my voice cq message. That would be handy for portable. 73. Lee, VE4DXR
Options/Audio config
User guide page 17 'Voice Keyer'
VE4DXR
Post by VE4DXR »
Hello Terry and Team.
I just returned from 4 weeks on my boat and had 971 QSO's on voice; activating 3 Light stations on Lake Winnipeg. I could not get the voice keyer to work on V.25. Followed the instructions in the manual. Used the built in mic on the laptop. The software played the recording in the settings screen but not from the PTT button at the qso screen. Using Signalink USB which did not key the 857d.
Any ideas what I did wrong? Also, how do you erase or delete a recording? 73. Lee, VE4DXR
The 'PTT' button on the main window is just for activating the radios transmit function it is not for playing back audio messages from Log4OM - I have just tested this function and it is working fine with the PTT triggered via a com port.
I would not expect this button to trigger the TX on your radio when using a Signalink because the Signallink only triggers the PTT when it receives audio not a com port command.
The voice recorder is activated from the 'Radio' drop down menu by selecting 'PTT' (Must get this changed to Voice Keyer sometime) but remember that you must keep the message button depressed to send the message - Its click and hold not a toggle on and off
I have just tested that the voice keyer works and it functions 100% as designed
To delete a message either record over it or go to the Audio folder and delete the files (Help/Open configuration folder)
df6vi
Post by df6vi »
So far, so good for recording and saving the messages (CQ, QRZ...) but when i try to send it (PTT switches correctly), but nothing else happens. Even no sound for monitoring the message. All quiet.
Rig FT-DX3000
73' Stefan - DF6VI
I already responded to this question in the German Language thread but here it is again
You either have not selected the correct sound card that is used by the radio nor you have it set up incorrectly on the radio or in Windows Sound devices.
Dont forget to keep the button pressed
