New mode integration
DJ6JZ
Post by DJ6JZ » 20 Oct 2016, 15:23
I just made my first contact in the new SIM31 mode. When logged in Log4OM, this qso is marked as "PSK31" with a wrong frequency (PSK31 frequency).
Could this mode please be integrated?
More information about SIM31 can be found here:
http://www.sim.on2vhf.be/
Thank you!
vy 73,
Willi, DJ6JZ
http://www.radio-portal.org/sdr.html
SDR-Special
http://www.sdr-portal.de/index.html
SDR-Portal, mobile version
Re: New mode integration
Post by G4POP » 20 Oct 2016, 16:42
Options/Select config tab
Check the 'Enable expert mode' box
Click 'Mode list' button
Add the mode(s) that you require
File/Save
Restart Log4om
DJ6JZ
Post by DJ6JZ » 20 Oct 2016, 18:01
Thank you so much, Terry.
Worked fine. Now eqsl refuses the upload of my log: "Bad Mode SIM31".
I'll have to work me through, I guess...
vy 73,
Willi, DJ6JZ
Post by G4POP » 20 Oct 2016, 19:59
Unfortunately EQSL don't use the latest ADIF format so you need to find out what mode they will accept for those that you are using.
You will then need to edit your QSO modes to conform to the requirements of EQSL, but don't forget that those modes may not be acceptable to LOTW etc
DJ6JZ
Post by DJ6JZ » 20 Oct 2016, 23:34
Ok, Terry, understood. In the eqsl forum I found an explanation from VK3KAB who reported how to deal with SIM logs. It may be of use for other users of this mode:
"The reason no loggers have the ability to log SIM31 QSO is because it has still not been added to the ADIF spec.
For mode, at the moment you need to use PSK31, and adding SIM31 to the comments is a good idea.
Once it does get added with the next version of the ADIF spec (3.0.5), it is going to be Mode=PSK, Submode=SIM31 but no idea when that will be, they have been working on 3.0.5 for more than a year now."
vy 73,
Willi, DJ6JZ
Post by G4POP » 21 Oct 2016, 06:49
DJ6JZ wrote:Once it does get added with the next version of the ADIF spec (3.0.5), it is going to be Mode=PSK, Submode=SIM31
I am not even sure SIM31 has been proposed as an additional mode in ADIF yet, so it might not be in 3.0.5!
DJ6JZ
Post by DJ6JZ » 26 Oct 2016, 21:27
Those different ADIF versions are a problem. My logs are now compliant to eqsl. Now a qrz.com user refused to qsl because of wrong mode (PSK31)... :roll:
Ok, but I can offer a solution to another related problem within Log4OM:
SIM31 logs are shown as PSK31 in Log4OM for the reason you explained. But also the frequency (14067 kHz) is altered to 14073 kHz automatically. Trying to changing it back to the correct frequency in the "Recent QSO" window (right mouse click -Edit) will then change the SNR value to "599". So entering the correct frequency leads to a loss of accuracy in the RST windows.
Solution: Open the QSO Manager. Check "Enable update". Change the frequency manually. Then the frequency is stored correctly without an effect to the RST values.
HTH, vy 73,
Willi, DJ6JZ
bernard
Post by bernard » 09 Feb 2018, 18:17
Bonjour
Et pour changer le report 599 pour un report - ou+ ?
Post by G4POP » 09 Feb 2018, 18:35
As a user it is your choice if you want to add SIM31, or any other mode to the list, just use expert mode in the Options and edit the modes
If you also want to provide a 599 report for SIM31 edit the modelist.csv file by adding SIM31 to the list of Data modes, this file is in your Log4OM configuration folder - Help/ view configuration folder
Log4Om is as user configurable as you wish to make it but please be aware that SIM31 is not a supported mode in the latest ADIF specification and it is not so far proposed for the next ADIF release!
bernard
Post by bernard » 24 Feb 2018, 11:26
Merci
J'ai réussi à intégré le report + ou - au lieu du 599
